[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
Rainer M Krug
Rainer at krugs.de
Mon Feb 6 10:05:53 PST 2017
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Mon, Feb 6, 2017 at 8:50 AM, Markus Neteler <neteler at osgeo.org> wrote:
> > Otherwise, there is no problem at all with using the git repo.
> Perhaps yes if that brings back the Mac tests at lowest cost
> Assuming that the Homebrew repo will be tested separately, the question is if we want to bring in another dependency - OSGeo Subversion to GitHub sync - or if we want to keep
> dependencies to minimum. For now, getting code from GitHub is the only way it works because of the broken SSL certificates, so sure we can use it, but that's for now.
I can look into these issues beginning of March but I agree that that
using the github would be the best solution and the homebrew should be
tested separately.
Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170206/8f7d0ebe/attachment.sig>
