[GRASS-dev] [GRASS GIS] #3278: Unble to import an AQUA image data (Level 2)in netcdf file format
GRASS GIS trac at osgeo.org
Tue Feb 7 07:37:08 PST 2017
  Reporter:  laurent001  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.1
 Component:  LibRaster   |    Version:  unspecified
Resolution:              |   Keywords:  r.in.gdal
       CPU:  x86-64      |   Platform:  MacOSX
Comment (by Veronica Andreo):
 I just checked. It seems it is not supported (gdal 2.0.2)
 gdalinfo A2017012160000.L2_LAC_OC.nc
 Warning 1: Variable has 0 dimension(s) - not supported.
 gdalinfo failed - unable to open 'A2017012160000.L2_LAC_OC.nc'.
 Global Level 3 products are recognized and imported normally, though:
 r.in.gdal -o -l
 input=NETCDF:A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc:chl_ocx
 output=prueba_clor_new
 Maybe, SeaDAS, the software provided by NASA for oceancolor, is needed to
 read L2 products and export into a different format. Just guessing, no
 idea.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3278#comment:2>
