[GRASS-dev] Cannot move temp file with os.rename change
    Martin Landa
    landa.martin at gmail.com
    Wed Feb  8 02:10:39 PST 2017
2016-09-12 14:08 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
This should be fine since we are renaming file in current directory:
> ./scripts/r.in.srtm/r.in.srtm.py:    os.rename(hgtfile, bilfile)
These should be fine also since we expect gisdbase to be on one
physical drive (?):
> ./gui/wxpython/gis_set.py:
> os.rename(os.path.join(self.gisdbase, location, mapset),
> os.rename(os.path.join(self.gisdbase, location),
Items bellow should be also fine since we are renaming file in given directory:
> ./gui/wxpython/rlisetup/frame.py:
> os.rename(os.path.join(self.rlipath, confile), newname)
> ./lib/python/gunittest/reporters.py:    os.rename(tmp_file_path, file_path)
> ./man/build_html.py:        os.rename(temp, name)
> ./man/build_rest.py:        os.rename(temp, name)
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
