[GRASS-dev] Broken: GRASS-GIS/grass-ci#1922 (master - 0202aa0)
Travis CI
builds at travis-ci.org
Wed Feb 8 09:59:36 PST 2017
Build Update for GRASS-GIS/grass-ci
Build: #1922
Status: Broken
Duration: 5 minutes and 12 seconds
Commit: 0202aa0 (master)
Author: Huidae Cho
Message: Call the DB error handler before the vector handler to avoid busy database warnings
Reproduce this issue in the North Carolina sample dataset:
r.to.vect input=aspect output=aspect type=line
Any unthinned input raster will produce the same issue.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70506 15284696-431f-4ddb-bdfa-cd5b030d7da7
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/93d80574f7fc...0202aa0464d6
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/199695525
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170208/314606bc/attachment.html>
