[GRASS-dev] [GRASS GIS] #3279: Add Region tab to the main GUI
trac at osgeo.org
Wed Feb 8 19:23:31 PST 2017
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Keywords: g.region, extent, resolution, | CPU: Unspecified
novice, beginner, user-friendliness |
Platform: Unspecified |
I suggest to add another tab to the Layer Manager which would handle (and
show) all things related to the (current) computational region. The name I
suggest for the tab is ''Region'' and the order:
* Layers
* [3D view]
* Console
* ''Region''
* Modules
* Data
* Python
I'm not sure how it should look like or how it should be updated (it can
be modified from outside of the widget). There can be only basic
functionality and button to start g.region (see ''Modules'' tab). For
example, if the tab is active, the Map Display could active the "Show
comp. extent" option. I'm attaching a screenshot of how this looks like in
the QGIS GRASS plugin. I'm not sure about the aesthetics of it, but the
functionality is probably at least the minimum of what we want. I'm not
sure how nswe are useful but we can add raster and vector option and the
alignment function (although they are probably better handled through
Layers), -a flag, named regions ("bookmarking") and maybe other things
handled from Map Display.
This may raise awareness of new users about computational region and
encourage all users to remember it before running modules. There can be
even a short explanation what does it do.
Problems:
* Name: ''Region'' is not completely clear, but we decided to go with one
word, so ''Computational Region'' is not an option. ''g.region'' would be
less readable for novices and inconsistent.
* Although for English there is still space even when ''3D view'' is
active, we may be running out of space for some languages.
* How many of these tabs do we what to add (allowed to be added) there?
* Spatial Database, Location, Mapset
* Thing related to Map Display, Vector Digitizer, ... (as for 3D view)
* General preferences which needs to be changed often (Map Display color,
font, projection statusbar settings)
* Documentation (Doc, Man)
* R, Jupyter Notebook, ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3279>
