[GRASS-dev] v.in.osm
Moritz Lennert
mlennert at club.worldonline.be
Thu Feb 9 04:47:38 PST 2017
On 09/02/17 10:20, Luca Delucchi wrote:
> Hi,
> I did a change in v.in.osm adding a c flag to cleanup the data and
> create a GRASS GIS network topological correct, this is done by
> default now. I attached a diff.
> The flag could be also the opposite, so don't cleanup the data.
> What do you think?
I would not make it the default. You cannot be sure that users want to
clean in the same way you do, so better to provide it as an
(well-documented) option.
Moritz
