[GRASS-dev] [GRASS GIS] #3244: Vect_get_map_box() and level1
GRASS GIS trac at osgeo.org
Fri Feb 10 01:20:22 PST 2017
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  vlib, map bbox, level1
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:3 martinl]:
 > Touching `plus_head` structure on level1 is not good idea since this
 structure is designed for topological level 2. I modified patch by
 introducing `Vect_get_map_box1()` which works on level1. See
 attachment:get_map_box_1.diff. On level 1 `Vect_get_map_box()` returns
 error code.
 Implemented in r70521.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3244#comment:4>
