[GRASS-dev] [GRASS GIS] #2055: r.in.gdal lacks flag "-r Limit import to the current region"
trac at osgeo.org
Fri Feb 10 03:23:28 PST 2017
Reporter: neteler | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 7.2.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, r.import
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Replying to [comment:16 mmetz]:
> * if the current region and the input raster overlap only partially,
adjust the current region to avoid importing all-NULL rows/columns
The new version of patch attachment:r_in_gdal_2055_1.diff still fills the
whole grid of computation region. Cells outside of input raster grid are
filled by NULL values. The solution you are suggesting would make probably
better sense (avoid importing all-NULL rows/columns). I will take a look
at this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2055#comment:22>
