[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
GRASS GIS trac at osgeo.org
Sun Feb 12 09:00:28 PST 2017
  Reporter:  sbl          |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:8 martinl]:
 > Replying to [comment:5 mlennert]:
 > > Wouldn't something like this do the job ? :
 > this patch worked for you?
 I didn't try. It was just the result of a quick look at the code, not a
 real patch.
 > The overwrite check is done earlier by parser (since output is not
 G_OPT_F_OUTPUT)?
 Yes, right. So, you are probably right that this needs a parser-level
 solution.
 Sorry for the noise...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:9>
