[GRASS-dev] [GRASS GIS] #3286: Add Line_height as a valid attribute in v.to.db
GRASS GIS trac at osgeo.org
Tue Feb 14 05:29:46 PST 2017
 Reporter:  geografik                  |      Owner:  grass-dev@…
     Type:  enhancement                |     Status:  new
 Priority:  normal                     |  Milestone:  7.2.1
Component:  Database                   |    Version:  7.2.0
 Keywords:  Line_height, v.in.db, kml  |        CPU:  All
 Platform:  All                        |
 Imported kml files that include elevation data are structured generally as
 shown below in GRASS (this is an example of a contour line):
 east, north: -79.7630759471, 39.0874586371
 DBT at corH:
  Type: Line
  Length: 275.746
  Line_height: 698.602997
  Layer: 1
  Category: 885
  Driver: sqlite
  Database: /Users/sesMacBook/grassdata/KML/corH/sqlite/sqlite.db
  Table: DBT
  Key_column: cat
  Attributes:
    cat: 885
    cat_: 885
    tessellate: -1
    extrude: -1
    visibility: -1
 Elevation data is maintained in the Line_height field which is not a
 recognized attribute, and therefor precludes any further use of these data
 in GRASS - beyond simple display and labling.  3D analysis, for example,
 is not possible.  The suggested improvement to v.to.db would add
 Line_height to the list of attributes considered in this module so that
 the elevation data could become part of the recognized feature attributes
 and be useful in other modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3286>
