[GRASS-dev] [GRASS GIS] #3286: Add Line_height as a valid attribute in v.to.db
trac at osgeo.org
Tue Feb 14 08:07:13 PST 2017
Reporter: geografik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.1
Component: Database | Version: 7.2.0
Resolution: | Keywords: Line_height, v.in.db, kml
CPU: All | Platform: All
Description changed by martinl:
Old description:
> Imported kml files that include elevation data are structured generally
> as shown below in GRASS (this is an example of a contour line):
> east, north: -79.7630759471, 39.0874586371
> DBT at corH:
> Type: Line
> Length: 275.746
> Line_height: 698.602997
> Layer: 1
> Category: 885
> Driver: sqlite
> Database: /Users/sesMacBook/grassdata/KML/corH/sqlite/sqlite.db
> Table: DBT
> Key_column: cat
> Attributes:
> cat: 885
> cat_: 885
> tessellate: -1
> extrude: -1
> visibility: -1
> Elevation data is maintained in the Line_height field which is not a
> recognized attribute, and therefor precludes any further use of these
> data in GRASS - beyond simple display and labling. 3D analysis, for
> example, is not possible. The suggested improvement to v.to.db would add
> Line_height to the list of attributes considered in this module so that
> the elevation data could become part of the recognized feature attributes
> and be useful in other modules.
New description:
Imported kml files that include elevation data are structured generally as
DBT at corH:
Type: Line
Length: 275.746
Layer: 1
Category: 885
Driver: sqlite
Table: DBT
Key_column: cat
Attributes:
cat: 885
cat_: 885
tessellate: -1
extrude: -1
visibility: -1
recognized attribute, and therefor precludes any further use of these data
in GRASS - beyond simple display and labling. 3D analysis, for example,
Ticket URL: <https://trac.osgeo.org/grass/ticket/3286#comment:2>
