[GRASS-dev] [GRASS-SVN] r70632 - grass/trunk/scripts/v.report
Martin Landa
landa.martin at gmail.com
Sun Feb 19 23:39:21 PST 2017
are you planning to backport bugfixes to relb72? Thanks, Ma
2017-02-20 1:15 GMT+01:00 <svn_grass at osgeo.org>:
> Author: hcho
> Date: 2017-02-19 16:15:14 -0800 (Sun, 19 Feb 2017)
> New Revision: 70632
> Modified:
> grass/trunk/scripts/v.report/v.report.py
> Log:
> v.report: Fix unit=percent
> Modified: grass/trunk/scripts/v.report/v.report.py
> --- grass/trunk/scripts/v.report/v.report.py 2017-02-19 23:40:29 UTC (rev 70631)
> +++ grass/trunk/scripts/v.report/v.report.py 2017-02-20 00:15:14 UTC (rev 70632)
> @@ -81,7 +81,7 @@
> else:
> extracolnames = [option]
> - if units in ['p', 'percent']:
> + if units == 'percent':
> unitsp = 'meters'
> elif units:
> unitsp = units
> @@ -90,6 +90,7 @@
> # NOTE: we suppress -1 cat and 0 cat
> if isConnection:
> + f = grass.vector_db(map=mapname)[int(layer)]
> p = grass.pipe_command('v.db.select', quiet=True, map=mapname, layer=layer)
> records1 = []
> catcol = -1
> @@ -97,12 +98,12 @@
> cols = line.rstrip('\r\n').split('|')
> if catcol == -1:
> for i in range(0, len(cols)):
> - if cols[i] == 'cat':
> + if cols[i] == f['key']:
> catcol = i
> break
> if catcol == -1:
> - # shouldn't happen, but let's do this
> - catcol = 0
> + grass.fatal(_("There is a table connected to input vector map '%s', but "
> + "there is no key column '%s'.") % (mapname, f['key']))
> continue
> if cols[catcol] == '-1' or cols[catcol] == '0':
> continue
> @@ -115,7 +116,6 @@
> if len(records1) == 0:
> try:
> - f = grass.vector_db(map=mapname)[int(layer)]
> "there are no categories present in the key column '%s'. Consider using "
> "v.to.db to correct this.") % (mapname, f['key']))
> @@ -142,6 +142,7 @@
> for r2 in records2:
> records3.append(filter(lambda r1: r1[catcol] == r2[0], records1)[0] + r2[1:])
> else:
> + catcol = 0
> records1 = []
> p = grass.pipe_command('v.category', inp=mapname, layer=layer, option='print')
> for line in p.stdout:
> @@ -172,15 +173,18 @@
> numcols = len(colnames) + len(extracolnames)
> # calculate percents if requested
> - if units != '' and units in ['p', 'percent']:
> - # calculate total area value
> - areatot = 0
> + if units == 'percent' and option != 'coor':
> + # calculate total value
> + total = 0
> for r in records3:
> - areatot += float(r[-1])
> + total += float(r[-1])
> - # calculate area percentages
> - records4 = [float(r[-1]) * 100 / areatot for r in records3]
> - records3 = [r1 + [r4] for r1, r4 in zip(records1, records4)]
> + # calculate percentages
> + records4 = [float(r[-1]) * 100 / total for r in records3]
> + if type(records1[0]) == int:
> + records3 = [[r1] + [r4] for r1, r4 in zip(records1, records4)]
> + else:
> + records3 = [r1 + [r4] for r1, r4 in zip(records1, records4)]
> # sort results
> if options['sort']:
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
