[GRASS-dev] [GRASS GIS] #3293: r.texture: very slow when size is increased
trac at osgeo.org
Mon Feb 20 23:42:01 PST 2017
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture speed
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3293 mlennert]:
> Running
> r.texture -a ortho_2001_t792_1m size=27 out=text_ortho_27
> in the NC demo data set took the following time:
> real 339m54.922s
> user 339m44.824s
> sys 0m5.464s
> This seems excessively long, especially when the relevant literature
cites common sizes of 20-50 (see #3210 for a discussion).
Note that e.g. Haralick et al. (1973) did not use a moving window
approach, instead texture measurements were calculated for selected blocks
and the output is not a raster map but a single value for each texture
measurement and each block.
> It would be great if this could somehow be accelerated.
Maybe by processing moving windows in parallel, at the cost of allocating
/ freeing memory for each moving window.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3293#comment:1>
