[GRASS-dev] [GRASS GIS] #3293: r.texture: very slow when size is increased
trac at osgeo.org
Tue Feb 21 02:07:34 PST 2017
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture speed
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:3 mmetz]:
> Replying to [comment:2 mlennert]:
> > Replying to [comment:1 mmetz]:
> > > Replying to [ticket:3293 mlennert]:
> > > > It would be great if this could somehow be accelerated.
> > > Maybe by processing moving windows in parallel, at the cost of
allocating / freeing memory for each moving window.
> > Yes, I've thought about this as well. This seems like a perfect
example of a module that could profit from parallelisation across as many
cores/threads the user choses. Memory usage is very low, so this will not
be a bottleneck (except for large images as the module still reads in the
entire data, no ?). And allocation only has to happen once at the
beginning, and then you can just use the allocated window throughout, or ?
> No, because if you process moving windows in parallel, you process
several moving windows at the same time. Therefore you would need to
allocate + free memory for each moving window, otherwise the different
moving windows would overwrite each other's results.
Yes, but you would only need one window per process, and you would only
allocate each process window once, at the beginning, or ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3293#comment:4>
