[GRASS-dev] [GRASS GIS] #2757: r.import: ERROR: Input raster map is outside current region
GRASS GIS trac at osgeo.org
Wed Feb 22 01:16:42 PST 2017
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:  7.0.6
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.import
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:16 hellik]:
 > I've seen some related commits to this: r70642, r70643, r70644, r70645,
 r70646, r70647
 also r70656
 > any test cases, hints how to test this new feature?
 Population for Madagascar from http://www.worldpop.org.uk/
 resolution is 0.000833300000000, should be 0.000833333333333
 GRASS 7.2
 N: 11:57:04.9988S    S: 25:36:24.03236S   Res: 0:00:02.99988
 E: 50:29:05.949529E    W: 43:11:16.000369E   Res: 0:00:02.99988
 trunk
 trunk, automatic adjustment
 N:  11:57:05S    S:  25:36:26S   Res: 0:00:03
 E:  50:29:07E    W:  43:11:16E   Res: 0:00:03
 worldclim global 2.5 minutes
 GRASS 7.2
 N:        90N    S:        60S   Res: 0:02:30
 E:       180E    W:       180E   Res: 0:02:30
 -> West is wrong, must be 180W
 trunk
 E:       180E    W:       180W   Res: 0:02:30
 CHELSA version 1.1
 GRASS 7.2
 N: 83:59:59.497495N    S:        90S   Res: 0:00:29.999976
 E: 179:59:59.494816E    W: 179:59:59.5E   Res: 0:00:30
 -> South has been cut
 -> West is too far east,
    East will silently be wrapped by lib/gis/adj_cellhd.c:L119,120
    to 539:59:59.494816E, causing all sorts of problems
 trunk
 N: 83:59:59.497495N    S: 90:00:00.5S   Res: 0:00:30
 E: 179:59:59.494816E    W: 180:00:00.5W   Res: 0:00:30
 N: 83:59:59.5N    S: 90:00:00.5S   Res: 0:00:30
 E: 179:59:59.5E    W: 180:00:00.5W   Res: 0:00:30
 The automatic adjustment in trunk is not yet used by any module,
 candidates are r.in.gdal, r.external, r.region.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2757#comment:17>
