[GRASS-dev] correction r.mapcalc help file
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Feb 23 06:33:46 PST 2017
Dear devs,
In the help file of r.mapcalc it is written:
> When the user enters input to /r.mapcalc/ non-interactively on the
> command line, the program will not warn the user not to overwrite
> existing map layers. Users should therefore take care to assign
> program outputs raster map names that do not yet exist in their
> current mapsets.
Perhaps the description is somewhat ambiguous, but if the way I read
this is correct, this is not the default behaviour. Perhaps the
following describes it better:
> By default it is not possible to overwrite existing raster layers, so
> the user is expected to take care to assign program output raster
> names that do not yet exist in their current mapset. If they want to
> overwrite existing maps, users can use the --overwrite flag.
I added a patch file in case the above is ok.
Best wishes,
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170223/e231763e/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170223/e231763e/attachment.bin>
