[GRASS-dev] [GRASS GIS] #2875: Python testsuite failing with UnicodeDecodeError
trac at osgeo.org
Sun Feb 26 11:41:57 PST 2017
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by wenzeslaus):
Replying to [comment:7 marisn]:
> Replying to [comment:4 wenzeslaus]:
> > Replying to [ticket:2875 marisn]:
> > > Unfortunately it is not possible to run tests as test suite is
failing itself...
> > > module.run()
> > > File ".../grass/pygrass/modules/interface/module.py", line 713, in
run
> > > module=self.name, errors=stderr)
> > Since this comes from ''grass.pygrass.modules'', can you try the
''Module'' class separately?
> Can you provide code for testing?
Please use any PyGRASS documentation to execute a module using the
''Module'' class (open an a separate ticket if you can't find it). It
should be something like (pseudo-code based on the above):
#!python
module = Module('r.mapcalc', expression='rand_x = rand(1, 200)')
module.run()
# An error should occur because we use ''rand()'' without a seed info.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2875#comment:8>
