[GRASS-dev] [GRASS GIS] #2114: m.nviz.image does not work on Windows
trac at osgeo.org
Sun Feb 26 19:31:49 PST 2017
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: LibOpenGL | Version: svn-trunk
Resolution: | Keywords: m.nviz.image
CPU: Unspecified | Platform: All
Changes (by wenzeslaus):
* platform: MSWindows 7 => All
Comment:
This now seems to be an issue on Linux as well. On Ubuntu 16.04:
> m.nviz.image elevation_map=elevation output=test format=ppm size=640,480
X Error of failed request: BadValue (integer parameter out of range for
operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 24
Current serial number in output stream: 29
Changing platform to all. New ticket more appropriate? New implementation
seems to be necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2114#comment:8>
