[GRASS-dev] [GRASS GIS] #2233: wxGUI d.mon and g.gui monitor command line support
GRASS GIS trac at osgeo.org
Sun Feb 26 20:01:00 PST 2017
  Reporter:  wenzeslaus   |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  minor        |  Milestone:  7.4.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  d.mon, display, d.* commands
       CPU:  Unspecified  |   Platform:  All
Comment (by wenzeslaus):
 d.erase is supported in wxGUI since r70232 (trunk == 7.4svn).
 d.mon could be supported in the way that wx0-9 would be
 starting/switching/closing the appropriate Map Displays (numbering is from
 1, so wx0 would be Display 1).
 d.path can be probably supported as any other d. command.
 It should be possible to support d.font and d.fontlist in some reasonable
 way.
 d.info can be supported in some basic way.
 d.rast.edit can start the wxGUI raster digitizer although it is not 100%
 the same functionality.
 Should d.profile start wxGUI profiling tool?
 d.what.rast and d.what.vect can probably just start the query dialog.
 I'm not sure what to do with d.colorlist and d.where.
 d.frame might be little too much for GUI to handle, although exactly
 something like this is needed there.
 d.zoom does not exist in 7.0. There is probably no need for its 6.4
 functionality, but in GUI it could do things like activate the interactive
 setting of region (6.4 functionality) or zoom to raster/vector (right
 click on layer functionality).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2233#comment:4>
