[GRASS-dev] g.version build failing with --with-sqlite-includes
Michel Wortmann
wortmann at pik-potsdam.de
Mon Feb 27 04:46:29 PST 2017
Hi Markus,
here is the complete g.version make error (I have replaced the server
critical paths with $builddir, $installdir and $pkgdir):
./configure --prefix=$installdir \
--enable-shared \
--enable-64bit \
--enable-largefile \
--with-readline \
--with-gdal \
--with-sqlite \
--with-sqlite-libs=$pkgdir/anaconda/4.2.0/lib \
--with-sqlite-includes=$pkgdir/anaconda/4.2.0/include \
--with-geos \
--with-png \
--without-wxwidgets \
--with-netcdf \
--with-proj-includes=$pkgdir/proj4/4.9.3/include \
--with-proj-share=$pkgdir/proj4/4.9.3/share/proj \
--with-proj-libs=$pkgdir/proj4/4.9.3/lib \
--with-freetype-include=/usr/include/ \
--with-freetype-libs=/usr/lib/ \
--with-includes=/usr/include/freetype2 \
--with-python \
--without-opengl \
--without-fftw
cd general/g.version
gcc -I/usr/include/freetype2 -g -O2 -I/usr/include/freetype2 -I$builddir/grass-7.2.0/dist.x86_64-pc-linux-gnu/include -I$builddir/grass-7.2.0/dist.x86_64-pc-linux-gnu/include \
-I$pkgdir/proj4/4.9.3/include -I$pkgdir/gdal/2.1.3/include -I$pkgdir/geos/3.6.1/include -DGRASS_VERSION_NUMBER=\"'7.2.0'\" -DGRASS_VERSION_DATE=\"'2016'\" \
-DGRASS_VERSION_SVN=\"'exported'\" -DGRASS_VERSION_UPDATE_PKG=\"''\" -DARCH=\"'x86_64-pc-linux-gnu'\" -DPACKAGE=\""grassmods"\" \
-I$builddir/grass-7.2.0/dist.x86_64-pc-linux-gnu/include -I$builddir/grass-7.2.0/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"general/g.version\" -o OBJ.x86_64-pc-linux-gnu/main.o -c main.c
main.c:37:21: fatal error: sqlite3.h: No such file or directory
compilation terminated.
../../include/Make/Compile.make:32: recipe for target 'OBJ.x86_64-pc-linux-gnu/main.o' failed
make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Error 1
As I said, with -I$pkgdir/anaconda/4.2.0/include it worked fine.
Michel
On 02/22/2017 09:07 PM, Markus Neteler wrote:
> On Wed, Feb 22, 2017 at 1:13 PM, Michel Wortmann
> <wortmann at pik-potsdam.de> wrote:
>> Hi team,
>> it's really a minor issue, but wanted to let you know that I just built
>> grass-7.2.0 (on Suse SLE 12.2) configured with the
>> --with-sqlite-includes=/path/include flag. I got an error in
>> general/g.version complaining that it cant find sqlite3.h.
> Please post it completely, so that we can analyse the issue.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170227/f9e82dbc/attachment-0001.html>
