[GRASS-dev] [GRASS GIS] #3235: Vect_cidx_find_all should not allow mixing GV_AREA with other geometries
trac at osgeo.org
Sun Jan 1 11:44:12 PST 2017
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.1
Component: LibVector | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
At the moment Vect_cidx_find_all accepts any type mask. This leads to
unusable results in case if typemask allows both GV_LINES and GV_AREA in
the output. Reason - Vect_cidx_find_next will return line ID for GV_LINES
and area ID for GV_AREA. As both ID spaces are separate (thus might
contain identical ID values), mixing them in a single output structure is
a road to disaster.
The fix - Vect_cidx_find_all should fail to accept type mask matching
GV_LINES and GV_AREA (other combinations?) simultaneously.
Other option - change Vect_cidx_find_all to modify two structs - one with
line IDs and other with area IDs.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3235>
