[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1837 (master - 542a054)
Anna Petrášová kratochanna at gmail.com
Sat Jan 7 14:24:19 PST 2017
On Sat, Jan 7, 2017 at 5:00 PM, Travis CI <builds at travis-ci.org> wrote:
> *GRASS-GIS / grass-ci <https://travis-ci.org/GRASS-GIS/grass-ci>* (master
> <https://github.com/GRASS-GIS/grass-ci/tree/master>)
> Build #1837 is still failing.
> <https://travis-ci.org/GRASS-GIS/grass-ci/builds/189871967>
> 12 minutes and 48 seconds
> *Anna Petrášová* 542a054
> <https://github.com/GRASS-GIS/grass-ci/commit/542a054d805b7c5243f7672923f25b9075e667fa> Changeset
> <https://github.com/GRASS-GIS/grass-ci/compare/2f8413b50c12...542a054d805b>
>   v.surf.rst: fix compilation for clang
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70294
> 15284696-431f-4ddb-bdfa-cd5b030d7da7
> *Want to know about upcoming build environment updates?*
> Would you like to stay up-to-date with the upcoming Travis CI build
> environment updates? We set up a mailing list for you! Sign up here
> <http://eepurl.com/9OCsP>.
> Documentation <https://docs.travis-ci.com> about Travis CI
> Need help? Mail support <support at travis-ci.com>!
> Choose who receives these build notification emails in your configuration
> file <https://docs.travis-ci.com/user/notifications>.
> *Would you like to test your private code?*
> Travis CI for Private Projects
> <https://travis-ci.com?utm_source=build_email_footer&utm_campaign=travis-ci.org&utm_medium=email>
> could be your new best friend!
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Hi, it's failing on Mac only, but I don't see a log, so I can't fix it. I
can look at it on Monday if that's ok.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170107/f5e5f638/attachment-0001.html>
