[GRASS-dev] [GRASS GIS] #3243: v.in.pdal build error: some PDAL 1.4.0 includes are not where the module expects them
GRASS GIS trac at osgeo.org
Sun Jan 8 11:48:16 PST 2017
expects them
  Reporter:  msieczka  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.2.1
 Component:  Vector    |    Version:  7.2.0
Resolution:            |   Keywords:
       CPU:  All       |   Platform:  All
Comment (by neteler):
 I have attached a patch which solves the changes include paths.
 However, I get several compilation errors with PDAL 1.4.0. Due to API
 changes?
 [neteler at oboe v.in.pdal]$ make
 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but
 not for C
 not for C
 c++  -g -Wall  -I/home/neteler/software/grass72/dist.x86_64-pc-linux-
 gnu/include -I/home/neteler/software/grass72/dist.x86_64-pc-linux-
 gnu/include   -I/usr/include/gdal -I/usr/include -O2 -g -pipe -Wall
 -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-
 protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches
 -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic -Wextra
 -Wall -Wno-unused-parameter -Wno-unused-variable -Wpointer-arith -Wcast-
 align -Wcast-qual -Wredundant-decls -Wno-long-long -Wno-unknown-pragmas
 -Wno-deprecated-declarations -isystem /usr/local/include -std=c++11
 -std=c++11 -DPACKAGE=\""grassmods"\"   -I/usr/include/gdal -I/usr/include
 -I/usr/include/gdal -I/usr/include/libxml2 -I/usr/include -I/usr/include
 -I/home/neteler/software/grass72/dist.x86_64-pc-linux-gnu/include
 -DRELDIR=\"vector/v.in.pdal\" -o OBJ.x86_64-pc-linux-gnu/main.o -c
 main.cpp
 main.cpp:62:47: error: ‘pdal::Dimension::Id::Enum’ has not been declared
                           pdal::Dimension::Id::Enum dim_to_use_as_z)
 main.cpp: In function ‘void pdal_point_to_grass(Map_info*, line_pnts*,
 line_cats*, pdal::PointViewPtr, pdal::PointId, GLidarLayers*, int, int)’:
 main.cpp:67:38: error: ‘Id’ is not a namespace-name
      using namespace pdal::Dimension::Id;
 main.cpp:67:40: error: expected namespace-name before ‘;’ token
 main.cpp:68:47: error: ‘X’ was not declared in this scope
      double x = point_view->getFieldAs<double>(X, idx);
 main.cpp:69:47: error: ‘Y’ was not declared in this scope
      double y = point_view->getFieldAs<double>(Y, idx);
 main.cpp:70:67: error: no matching function for call to
 ‘pdal::PointView::getFieldAs(int&, pdal::PointId&)’
      double z = point_view->getFieldAs<double>(dim_to_use_as_z, idx);
 In file included from main.cpp:2:0:
 /usr/include/pdal/PointView.hpp:116:7: note: candidate: template<class T>
 T pdal::PointView::getFieldAs(pdal::Dimension::Id, pdal::PointId) const
      T getFieldAs(Dimension::Id dim, PointId pointIndex) const;
 /usr/include/pdal/PointView.hpp:116:7: note:   template argument
 deduction/substitution failed:
 main.cpp:70:67: note:   cannot convert ‘dim_to_use_as_z’ (type ‘int’) to
 type ‘pdal::Dimension::Id’
 main.cpp:78:52: error: ‘ReturnNumber’ was not declared in this scope
          int return_n = point_view->getFieldAs<int>(ReturnNumber, idx);
 main.cpp:79:53: error: ‘NumberOfReturns’ was not declared in this scope
          int n_returns = point_view->getFieldAs<int>(NumberOfReturns,
 idx);
 main.cpp:85:50: error: ‘Classification’ was not declared in this scope
                       point_view->getFieldAs<int>(Classification, idx));
 main.cpp:88:47: error: ‘Red’ was not declared in this scope
          int red = point_view->getFieldAs<int>(Red, idx);
 main.cpp:89:49: error: ‘Green’ was not declared in this scope
          int green = point_view->getFieldAs<int>(Green, idx);
 main.cpp:90:48: error: ‘Blue’ was not declared in this scope
          int blue = point_view->getFieldAs<int>(Blue, idx);
 main.cpp: In function ‘int main(int, char**)’:
 main.cpp:224:37: warning: ISO C++ forbids converting a string constant to
 ‘char*’ [-Wwrite-strings]
      max_ground_window_opt->answer = "33";
 main.cpp:233:32: warning: ISO C++ forbids converting a string constant to
      ground_slope_opt->answer = "1.0";
 main.cpp:241:39: warning: ISO C++ forbids converting a string constant to
      max_ground_distance_opt->answer = "2.5";
 main.cpp:250:40: warning: ISO C++ forbids converting a string constant to
      init_ground_distance_opt->answer = "0.15";
 main.cpp:259:36: warning: ISO C++ forbids converting a string constant to
      ground_cell_size_opt->answer = "1";
 main.cpp:326:5: error: ‘Enum’ is not a member of ‘pdal::Dimension::Id’
      pdal::Dimension::Id::Enum dim_to_use_as_z = pdal::Dimension::Id::Z;
 main.cpp:479:20: error: ‘eHorizontalOnly’ is not a member of
 ‘pdal::SpatialReference’
              getWKT(pdal::SpatialReference::eHorizontalOnly);
 main.cpp:541:9: error: ‘dim_to_use_as_z’ was not declared in this scope
          dim_to_use_as_z = point_view->layout()->findDim("Height");
 main.cpp:549:29: error: ‘dim_to_use_as_z’ was not declared in this scope
      if (!point_view->hasDim(dim_to_use_as_z))
 main.cpp:570:51: error: ‘dim_to_use_as_z’ was not declared in this scope
 ../../include/Make/Compile.make:35: recipe for target 'OBJ.x86_64-pc-
 linux-gnu/main.o' failed
 make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Error 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3243#comment:1>
