[GRASS-dev] [GRASS GIS] #3242: Gui does not disply correctly and locks up when scrolling down to make alternative mapsets visible in d.vect and d.rast.
trac at osgeo.org
Sun Jan 8 13:44:31 PST 2017
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.6
Component: wxGUI | Version: 7.2.0
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by ewcgrass):
I ran TreeMixin.py per your example, then ComboCtrl.py and TreeCtrl.py.
Everything in the windows that opened appeared to run fine. This is a copy
of the messages that came up on the terminal:
[rick at localhost ~]$ python /usr/share/doc/wxPython-docs/demo/TreeMixin.py
Python 2.7.12 (default, Sep 29 2016, 12:52:02)
[GCC 6.2.1 20160916 (Red Hat 6.2.1-2)]
wx.version: 3.0.2.0 gtk3 (classic)
(TreeMixin.py:520): Gtk-CRITICAL **: gtk_widget_set_size_request:
assertion 'height >= -1' failed
gtk_widget_get_preferred_width_for_height: assertion 'height >= 0' failed
(TreeMixin.py:520): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to
allocate widget with width 18 and height -8
File "/usr/share/doc/wxPython-docs/demo/TreeMixin.py", line 199, in
OnPageChanged
oldTree = self.GetPage(event.OldSelection)
File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk3/wx/_core.py", line
13536, in GetPage
return _core_.BookCtrlBase_GetPage(*args, **kwargs)
ValueError: in method 'BookCtrlBase_GetPage', expected argument 2 of type
'size_t'
OnPageChanged
13536, in GetPage
'size_t'
[rick at localhost ~]$ python /usr/share/doc/wxPython-docs/demo/ComboCtrl.py
17:36:36: ListCtrlComboPopup.Init
17:36:36: ListCtrlComboPopup.LazyCreate
17:36:36: ListCtrlComboPopup.Create
17:36:41: ListCtrlComboPopup.GetAdjustedSize: 250, 400, 934
17:36:41: ListCtrlComboPopup.OnPopup
17:36:41: ListCtrlComboPopup.SetStringValue
17:36:44: ListCtrlComboPopup.GetStringValue
17:36:44: ListCtrlComboPopup.SetStringValue
17:36:44: ListCtrlComboPopup.OnDismiss
(ComboCtrl.py:568): Pango-CRITICAL **: pango_layout_get_cursor_pos:
assertion 'index >= 0 && index <= layout->length' failed
[rick at localhost ~]$ python /usr/share/doc/wxPython-docs/demo/TreeCtrl.py
17:37:27: OnItemExpanded: Item 3
17:37:29: OnItemExpanded: item 3-b
17:37:31: OnSelChanged: item 3-b-0
17:37:35: OnItemExpanded: item 3-d
17:37:38: OnSelChanged: item 3-d-1
17:37:41: OnSelChanged: The Root Item
17:37:44: OnItemExpanded: Item 0
17:37:46: OnSelChanged: item 0-b
17:37:47: OnItemExpanded: item 0-b
17:37:48: OnSelChanged: item 0-b-1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3242#comment:6>
