[GRASS-dev] [GRASS GIS] #3242: Gui does not disply correctly and locks up when scrolling down to make alternative mapsets visible in d.vect and d.rast.
trac at osgeo.org
Mon Jan 9 06:31:50 PST 2017
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.6
Component: wxGUI | Version: 7.2.0
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by ewcgrass):
FYI, Scott Talbert has started to look at issue on Red Hat Bugzilla.
In additional trials, errors flooding terminal appears to be more related
to d.vect than to d.rast.
However, problem continues when creating new map displays in both d.vect
and d.rast. Also, the problem is intermittent when double-clicking on an
already displayed map layer in the layer manager, which opens say, d.vect,
for a displayed vector map. Then often (but not always) the scroll bar
does not display in the map selection drop-down window (must scroll using
mouse wheel). When scrolled all the way to the bottom of the drop-down
window to expose the additional mapsets (in blue, not expanded), all
usually appears fine. However, sometimes little arrow (triangle) to the
left of the mapset name appears and the mapset can be expanded, while
other times the triangle does not appear and clicking on the additional
mapset name locks up the GUI, accompanied as usual by 100% usage of one
CPU core by Xorg until stopping GRASS with Ctrl-D in the terminal.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3242#comment:14>
