[GRASS-dev] [GRASS-SVN] r70321 - grass/trunk/raster/r.in.xyz
Markus Neteler
neteler at osgeo.org
Mon Jan 9 09:33:04 PST 2017
Hi Martin,
On Mon, Jan 9, 2017 at 6:26 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi Markus,
> 2017-01-09 14:29 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> did you actually try?
>> I get this:
>> GRASS 7.2.1svn (utm32N):open_nrw_lidar > cat dgm1_32360_5620_2_nw.xyz
>> | tr -s ' ' ' ' | r.in.xyz input=- separator=space -s -g
> are you sure that you have fresh installation?
I think yes:
g.version -g
version=7.2.1svn
date=2017
revision=r70229M
build_date=2017-01-04
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
> Output is not requested when -s/g flags are given since [1].
> GRASS 7.2.1svn (gismentors_utm):~/geodata/DMR_5G > r.in.xyz
> input=HLIN04_5g.xyz separator=space -sg
> n=-1088000.076 s=-1090000.059 e=-624999.829 w=-627499.828 b=461.312 t=554.334
Weird. I had to use input=- because the number of space delimiters is
irregular in this dataset.
Would that influence it?
Markus
> ? Ma
> [1] https://trac.osgeo.org/grass/changeset?sfp_email=&sfph_mail=&reponame=&new=70291%40grass%2Fbranches%2Freleasebranch_7_2%2Fraster%2Fr.in.xyz%2Fmain.c&old=70188%40grass%2Fbranches%2Freleasebranch_7_2%2Fraster%2Fr.in.xyz%2Fmain.c
