[GRASS-dev] [GRASS-SVN] r70321 - grass/trunk/raster/r.in.xyz
Markus Neteler
neteler at osgeo.org
Mon Jan 9 14:01:26 PST 2017
On Mon, Jan 9, 2017 at 7:41 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2017-01-09 18:33 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> revision=r70229M
> the change has been done in r70291.
>>> GRASS 7.2.1svn (gismentors_utm):~/geodata/DMR_5G > r.in.xyz
>>> input=HLIN04_5g.xyz separator=space -sg
>>> n=-1088000.076 s=-1090000.059 e=-624999.829 w=-627499.828 b=461.312 t=554.334
>> Weird. I had to use input=- because the number of space delimiters is
>> irregular in this dataset.
>> Would that influence it?
> Also
> cat HLIN04_5g.xyz | r.in.xyz input=- separator=space -sg
I tried
https://grass.osgeo.org/grass72/manuals/r.in.xyz.html#import-of-x,y,z-ascii-into-dem
on my laptop at home and the example fails without output=..
Can anyone else please test? Thanks.
Markus
