[GRASS-dev] [GRASS GIS] #3248: v.external: mixed up IDs from PostGIS tables
trac at osgeo.org
Tue Jan 10 02:23:46 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: 7.0.5
Resolution: | Keywords: v.external
CPU: Unspecified | Platform: Unspecified
Description changed by martinl:
Old description:
> I tried to link a PostGIS table to GRASS GIS 7 for point sampling using
> v.external (in GRASS 7.0.6 and GRASS 7.2.1svn).
> With that linked layer (which is not in public schema and has column
> "point_id" as primary key) I get a lot of:
> WARNING: No record for category XXXX in table
> <myschema.points>
> when I use v.what.rast on that layer.
> The results suggest that not the proper IDs were used when values were
> loaded to attribute table. Because values in the attribute table of the
> points do not match with values in the raster at point locations.
> Furthermore, some points, which are supposed to have values in the
> attribute table, have none...
> With the attaced data, the issue can be reproduced like this:
> ogr2ogr -f PostgreSQL "PG:dbname=gisdata schemas=myschema" points.sqlite
> points
> v.external --overwrite input=PG:dbname=gisdata layer=myschema.points
> output=points_pg -o
> g.region -p -a vector=points res=250
> r.random.surface --overwrite --verbose output=rand
> v.what.rast map=points_pg raster=rand column=morphology
> Linking the SQLite data source however seems to work fine. No errors for:
> v.external --overwrite input=points.sqlite layer=myschema.points
> output=points_sqlite -o
> v.what.rast map=points_sqlite raster=rand column=morphology
> This is my PostGIS / GRASS environment:
> PostgreSQL 9.5.2 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
> 4.8.2-19ubuntu1) 4.8.2, 64-bit
> POSTGIS="2.2.2 r14797"
> GEOS="3.5.1-CAPI-1.9.1 r4171"
> SFCGAL="1.3.0"
> PROJ="Rel. 4.9.2, 08 September 2015"
> GDAL="GDAL 2.0.3, released 2016/07/01"
> For discussion see: https://lists.osgeo.org/pipermail/grass-
> dev/2017-January/083807.html
New description:
<myschema.points>
points
v.external --overwrite input=PG:dbname=gisdata layer=points
output=points_pg -o
g.region -p -a vector=points_pg res=250
SFCGAL="1.3.0"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3248#comment:1>
