[GRASS-dev] [GRASS GIS] #3248: v.external: mixed up IDs from PostGIS tables
trac at osgeo.org
Tue Jan 10 04:15:26 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: 7.0.5
Resolution: | Keywords: v.external
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Thanks Martin for the quick fix. I can confirm that the issue is solved in
r70330.
Leaving the ticket open until it is backported...
BTW:
GRASS_VECTOR_OGR=1 v.what.rast map=points_pg raster=rand column=morphology
did not work, but
GRASS_VECTOR_OGR=1 v.external --overwrite input=PG:dbname=gisdata
layer=points output=points_pg -o
did.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3248#comment:4>
