[GRASS-dev] [GRASS GIS] #3250: Build log is not visible for Mac OS on Travis CI
trac at osgeo.org
Tue Jan 10 15:22:14 PST 2017
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Keywords: travis-ci, osx, CI, testing, tests, | CPU: Unspecified
build, logs |
Platform: MacOSX |
The automatic build on Travis for Mac would be much more helpful if it
would include the compilation details as it does for Linux.
There is not that much difference between failed and passed build:
Failing: https://travis-ci.org/GRASS-GIS/grass-ci/jobs/189871970
Passing: https://travis-ci.org/GRASS-GIS/grass-ci/jobs/190733886
I don't know if it related to the fact that `osx` build is using Homebrew
instead of building straight from the source code in the repository. It is
good that brew build gets tested but I would expect that it would be done
in the same way as for `linux`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3250>
