[GRASS-dev] [GRASS GIS] #3249: v.what.rast: segfault with map without topology
trac at osgeo.org
Wed Jan 11 02:27:21 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Default | Version: svn-trunk
Resolution: | Keywords: v.what.rast, v. external
CPU: Unspecified | Platform: Unspecified
Changes (by martinl):
* keywords: v.what.rast => v.what.rast, v. external
Old description:
> Recently the requirement for topology was removed from v.what.rast.
> However, the module now segfaults if used with a vector map without
> topology.
> The issue can be reproduced with the workflow and data in #3248, but with
> v.external -b
> Related discussion here: https://lists.osgeo.org/pipermail/grass-
> dev/2017-January/083830.html
New description:
However, the module now segfaults if used with a *linked* vector map
without topology.
v.external -b
Ticket URL: <https://trac.osgeo.org/grass/ticket/3249#comment:1>
