[GRASS-dev] [GRASS GIS] #3249: v.what.rast: segfault with map without topology
trac at osgeo.org
Wed Jan 11 03:51:16 PST 2017
Reporter: sbl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.what.rast, level 1
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Seems to be a stack overflow somewhere since Map_info struct got ruined
before segfault:
gdb) p Map.dblnk->field[0]
$11 = {number = 6, name = 0x7600000344 <error: Cannot access memory at
address 0x7600000344>, driver = 0x60d770 "sqlite", database = 0x642100
"$GISDBASE/$LOCAT\005", table = 0x60d5f0 "pn18", key = 0x60d6b0 "cat"}
#0 _int_malloc (av=av at entry=0x7ffff6f86b00 <main_arena>,
bytes=bytes at entry=26) at malloc.c:3762
#1 0x00007ffff6c68d94 in __GI___libc_malloc (bytes=26) at malloc.c:2925
#2 0x00007ffff729e088 in G__malloc (file=0x7ffff72e166b
"lib/gis/location.c", line=82, n=26) at alloc.c:39
#3 0x00007ffff72aa7c1 in G__location_path () at location.c:82
#4 0x00007ffff72a4aaa in file_name (path=0x7fffffff9990 "\001", dir=0x0,
element=0x7fffffffae00 "vector/pn17", name=0x7ffff7bc2ed7 "dbln",
mapset=0x6095f0 "PERMANENT", base=0x0)
at file_name.c:107
#5 0x00007ffff72a4963 in G_file_name (path=0x7fffffff9990 "\001",
mapset=0x6095f0 "PERMANENT") at file_name.c:41
#6 0x00007ffff72c0743 in G__open (element=0x7fffffffae00 "vector/pn17",
name=0x7ffff7bc2ed7 "dbln", mapset=0x6095f0 "PERMANENT", mode=1) at
open.c:109
#7 0x00007ffff72c0929 in G_fopen_new (element=0x7fffffffae00
"vector/pn17", name=0x7ffff7bc2ed7 "dbln") at open.c:224
#8 0x00007ffff7b7ddcc in Vect_write_dblinks (Map=0x7fffffffbf40) at
field.c:923
#9 0x00007ffff7b7e395 in Vect_set_db_updated (Map=0x7fffffffbf40) at
field.c:1023
#10 0x00000000004027bc in main (argc=4, argv=0x7fffffffd9e8) at main.c:251
Ticket URL: <https://trac.osgeo.org/grass/ticket/3249#comment:7>
