[GRASS-dev] v.external: ID confusion
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Jan 11 03:54:38 PST 2017
Hi again,
And sorry, some more v.external issues...
When I try to connect to a remote server in GRASS 7.2.1svn with v.external, I get "database not found" error.
In GRASS 7.0 the database is found with exactly the same command.
However, linking the table fails in 7.0 because the ID column is in mixed cases and column names are not quoted in the SQL generated by v.external.
BTW. Is it necessary to sort the ID column? Does it make sense if UUIDs are used as primary keys?
Cheers
Stefan
-----Original Message-----
From: Martin Landa [mailto:landa.martin at gmail.com]
Sent: mandag 9. januar 2017 18.17
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] v.external: ID confusion
Hi Stefan,
2017-01-09 16:42 GMT+01:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Did I overlook something at import or should I open a ticket?
yes, please. Also provide all command and sample data to reproduce this issue. Thanks, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
