[GRASS-dev] [GRASS-SVN] r70321 - grass/trunk/raster/r.in.xyz
Luca Delucchi lucadeluge at gmail.com
Wed Jan 11 06:42:54 PST 2017
On 11 January 2017 at 12:08, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> GRASS 7.2.1svn (gismentors_utm):~/src/grass72_release > svn status
> (no uncommitted changes)
> Fresh compilation:
> g.version -g
> version=7.2.1svn
> date=2017
> revision=r70322
> build_date=2017-01-11
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> cat elevation.xyz
> 630007.5 228492.5 141.99614
> 630022.5 228492.5 141.37904
> 630037.5 228492.5 142.29822
> 630052.5 228492.5 143.97987
> GRASS 7.2.1svn (gismentors_utm):~/smetiste > r.in.xyz
> input=elevation.xyz separator=space -s -g
> n=228492.5 s=228492.5 e=630052.5 w=630007.5 b=141.37904 t=143.97987
> ? Ma
also for it works (using lidaratm2.txt from [0])
r.in.xyz in=/tmp/lidaratm2.txt sep=, -s -g
n=35.969493 s=35.949693 e=-75.620999 w=-75.639999 b=-1.937 t=200.935
[0] https://www.grassbook.org/wp-content/uploads/ncexternal/index.html
ciao
Luca
www.lucadelu.org
