[GRASS-dev] [GRASS GIS] #3256: v.krige fails to start due to missing core module
GRASS GIS trac at osgeo.org
Thu Jan 12 03:59:41 PST 2017
 Reporter:  marisn       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.2.1
Component:  Addons       |    Version:  svn-trunk
 Keywords:  v.krige      |        CPU:  Unspecified
 Platform:  Unspecified  |
 Since v.krige was moved to addons (see #3136), I am unable to start it. It
 seems that code was not changed to work as an addon.
 GRASS 7.3.svn (Latvija_LKS):~/soft/grass_trunk > v.krige
 Loading dependencies, please wait...
 /usr/lib64/python2.7/site-packages/rpy2/robjects/functions.py:106:
 UserWarning: rgeos version: 0.3-22, (SVN revision 544)
  GEOS runtime version: 3.5.0-CAPI-1.9.0 r4084
  Linking to sp version: 1.2-4
  Polygon checking: TRUE
   res = super(Function, self).__call__(*new_args, **new_kwargs)
 UserWarning:
 Attaching package: ‘XML’
 UserWarning: The following object is masked from ‘package:tools’:
     toHTML
 UserWarning: GRASS GIS interface loaded with GRASS version: GRASS 7.3.svn
 (2016)
 and location: Latvija_LKS
 UserWarning: Checking rgeos availability: TRUE
   File "/home/maris/.grass7/addons/scripts/v.krige", line 457, in <module>
     main()
   File "/home/maris/.grass7/addons/scripts/v.krige", line 333, in main
     from core import globalvar
 ImportError: No module named core
 env | grep PYTHON
 GRASS_PYTHON=python
 PYTHONPATH=/home/maris/soft/grass_trunk/dist.x86_64-pc-linux-
 gnu/etc/python
 core module is located in gui/wxpython/, still it is not in PYTHONPATH by
 default. Workaround till this issue is fixed: copy v.krige file from
 addons folder to GISBASE/gui/wxpython/
 Move to addons is also "interesting", as gui/wxpython/modules still
 contains vkriege.py GUI file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3256>
