[GRASS-dev] [GRASS GIS] #3249: v.what.rast: segfault with map without topology
trac at osgeo.org
Fri Jan 13 12:13:28 PST 2017
Reporter: sbl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.what.rast, level 1
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
> * probably also Vect_get_num_primitives should be modified to return -1
if topology is missing
Or the routine could return number of primitives by reading all features,
this issue is related conceptually with #3244. For now I changed module
back to require level2 (r70366).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3249#comment:11>
