[GRASS-dev] [GRASS GIS] #3263: r.to.vect: option to filter raster values
trac at osgeo.org
Tue Jan 17 10:45:33 PST 2017
Reporter: martinl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect, values
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
The attached patch attachment:r-to-vect-values.diff shows quick & dirty
way of implementing `values` option for G72:r.to.vect. This patch takes
code from G72:`d.rast` module (`mask.c`, `mask.h` and `parselist.c`) which
is not acceptable because of code duplication. The duplicated code should
be moved to `libgis` for real implementation.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3263#comment:1>
