[GRASS-dev] v.clean rmarea
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jan 23 01:14:17 PST 2017
On Mon, Jan 23, 2017 at 9:59 AM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Sun, Jan 22, 2017 at 3:46 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
> > On 21-01-17 21:29, Markus Metz wrote:
> > On Fri, Jan 20, 2017 at 8:37 PM, Paulo van Breugel <
> p.vanbreugel at gmail.com> wrote:
> > > Hi devs,
> > > I am trying to clean a map using v.clean. When using rmarea, any
> threshold values > 0.45 for rmarea results in 'ERROR: Failed to build new
> area'.
> > That should not happen, it is an error in the method to remove small
> areas. Can you provide the vector map for testing (offlist)?
> > Markus M
> > Hi Markus, the tool works as advertised after the latest revision. So
> perhaps this problem was related the the issue reported in ticket #3266?
> Thanks in any case!
> Glad to hear it is working. BTW, the relevant code was last changed 2
> years ago.
Ah, then I guess that was not the relevant code for the problem I
experienced. I regularly update grass, and I never experienced this problem
until recently. Perhaps there was something wrong on my side in that case?
Irrespective, very glad it works again :-)
> Markus M
> > > From the manual I understand that the threshold for rmarea must be in
> square meters (also for latitude-longitude locations). With areas of
> polygons at least being 50m2, and mostly well above 10000m2, I am not sure
> what is happening, any idea?
> > > Rgds
> > > Paulo
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170123/8fdf9ce4/attachment-0001.html>
