[GRASS-dev] v.clean threshold value unit for 'prune'
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Jan 26 08:22:48 PST 2017
On 26-01-17 14:38, Markus Metz wrote:
> On Thu, Jan 26, 2017 at 11:15 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > On 26-01-17 11:03, Markus Metz wrote:
> > On Thu, Jan 26, 2017 at 10:51 AM, Paulo van Breugel
> > > Hi
> > > I am using the v.clean tool with the option "prune". According to
> the manual, threshold values have to be in map units. I am using this
> with a latlon map with vertices as close as 0.0001 degrees. However,
> v.clean only removes vertices at threshold values of about 50 or up.
> This seems to suggest that the tools assumes threshold values are in
> meters?
> > The prune tool of v.clean never really worked. Please use
> v.generalize instead.
> > OK, will do. Still the question remains whether this is a bug, an
> error in the manual page (i.e., threshold values are not in mapping
> units, but in meters like for the rmarea) , or I am doing something
> wrong (note that it seems to work fine if one assumed threshold values
> have to be in meters). If a bug or error in the manual page, I can
> create a ticket.
> It's a bug in the code [0], the algorithm is not working properly.
> There is v.generalize, therefore I recommend to remove the prune tool
> from v.clean.
+1 if it doesn't work properly and it is a won't fix better to remove
> Markus M
> [0]
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/diglib/prune.c
> > Markus M
> > > Best wishes,
> > > Paulo
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170126/8fa1299f/attachment.html>
