[GRASS-dev] easy way to load x, y (of centroid) and top, bottom, left, right coordinates to attribute table?
Helmut Kudrnovsky
hellik at web.de
Sat Jan 28 03:19:15 PST 2017
>For the centroid coordinates:
>v.db.addcolumn YourMap column="x double precision, y double precision"
>v.to.db YourMap op=coor col=x,y
just tried with some vectors in a wgs84 ll location:
v.report map=testcalculate option=coor
cat|id|x|y|l|r|t|b|x2|y2|x|y|z
1||9.8489673562|47.0568937369|9.0801356183|10.6452349706|47.6779179411|46.4101061965|9.85074274819765|47.0584209060437|9.85074274819765|47.0584209060437|0.0
2||11.8802743895|46.9879350674|11.0347074901|12.7965928607|47.8068606443|46.1987432153|11.8761701610656|46.990400528994|11.8761701610656|46.990400528994|0.0
3||9.7422504597|46.163754262|9.0475885875|10.3944050709|46.4383355922|45.9348643802|9.737413876863|46.16534963624|9.737413876863|46.16534963624|0.0
x and y are the centroid coordinates calculated by QGIS
x2 and y2 are the centroi coordinates calculated by v.to.db
and the last (identical to x2 and y2) reported by v.report
it's interesting that QGIS and GRASS calculates differnt centroid
coordinates.
any idea?
>For the bounding box coordinates, I don't know any easy way. Would be a
>nice thing to have in v.to.db (see [1]).
yes indeed, would be a nice addition to v.to.db. updated the ticket.
taken from a little script coded some time ago:
# print bbox of vector layer geometries
if print_bbox_vector_geometries :
# open vector
vtopo = VectorTopo(vector)
vtopo.open(mode = 'r')
# loop thru vector geometries
for i in range(1, vcats_max_plus):
# get vector geometries area info
vect_geom_area = Area(v_id = i, c_mapinfo = vtopo.c_mapinfo)
# get vector geometries bbox info
vect_geom_bb = vect_geom_area.bbox()
# bbox north, south, west, east
bb_north = vect_geom_bb.north
bb_south = vect_geom_bb.south
bb_west = vect_geom_bb.west
bb_east = vect_geom_bb.east
grass.message("cat %s: north: %s south: %s west: %s east: %s" %(i,
bb_north, bb_south, bb_west, bb_east))
# close vector
vtopo.close()
so it's already in the vector data available, would be nice to have it in
v.to.db.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/easy-way-to-load-x-y-of-centroid-and-top-bottom-left-right-coordinates-to-attribute-table-tp5305135p5305175.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
