[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1897 (master - e395348)
Travis CI
builds at travis-ci.org
Sat Jan 28 20:54:42 PST 2017
Build Update for GRASS-GIS/grass-ci
Build: #1897
Status: Still Failing
Duration: 5 minutes and 5 seconds
Commit: e395348 (master)
Author: Václav Petráš
Message: wxGUI: lazy imports for lmgr and mapdisp
Avoids potential startup failures when dependencies are not met.
Insignificantly or potentially improves startup time.
Also removes unused imports (e.g. pylint -E --enable=unused-import).
Imports from core, gui_core etc. not reviewed (needs to be imported anyway).
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70450 15284696-431f-4ddb-bdfa-cd5b030d7da7
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/c2c3f90d8523...e3953483e94b
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/196275136
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170129/e2a31cbf/attachment.html>
