[GRASS-dev] [GRASS GIS] #2122: v.to.db: new variables to add
trac at osgeo.org
Mon Jan 30 01:39:44 PST 2017
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.to.db eigenvalues bbox
CPU: All | Platform: All
Comment (by hellik):
Replying to [comment:11 mlennert]:
> I finally decided to just go ahead and commit to facilitate testing
(r70451).
thanks for the implementation:
tested with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r70453
Build date: 2017-01-30
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
g.copy vector=lakes at PERMANENT,mylakes
Copy vector <lakes at PERMANENT> to current mapset as <mylakes>
v.to.db map=mylakes at user1 option=bbox columns=t,b,r,l
Reading areas...
Updating database...
15279 categories read from vector map (layer 1)
15279 records selected from table (layer 1)
15279 categories read from vector map exist in selection from table
15279 records updated/inserted (layer 1)
v.db.select map=mylakes at user1
cat|AREA|PERIMETER|FULL_HYDRO|FULL_HYDR2|FTYPE|FCODE|NAME|t|b|r|l
1|280261.46103|2853.9372|2|55626|LAKE/POND|39000||258302.909848466|258130.034036035|636012.26029972|635790.715367031
2|6754.6563|404.28643|3|55650|DAM/WEIR|34300||258248.323799814|258193.490779749|636431.09504699|636410.782219965
3|19512.86146|708.44683|4|55652|LAKE/POND|39000||258245.544932657|258192.348996665|636490.942646686|636425.805537212
4|1132.10986|151.16533|5|53514|LAKE/POND|39000||258212.396727567|258203.793649957|637196.254140018|637177.667259335
5|2849.43244|249.99941|6|53510|DAM/WEIR|34300||258210.786516747|258193.870561307|637209.225457828|637177.667259335
6|5908.42064|413.13377|7|55640|DAM/WEIR|34300||258181.2788371|258130.602489171|636960.29029048|636934.092252985
7|18807.73989|567.89134|8|55644|LAKE/POND|39000||258181.2788371|258125.193192754|636995.050850902|636941.778105157
8|5310.04399|334.89296|9|55660|LAKE/POND|39000||258172.628397222|258130.594259555|635797.542291085|635770.696062993
seems to work; nice addition to v.to.db.
>In the case of multiple features by category the module now calculates
the total bounding >box for all features with same category.
it's the best way to handle this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2122#comment:12>
