[GRASS-dev] new addon module: i.superpixels.slic - image segmentation using the SLIC segmentation method
Moritz Lennert mlennert at club.worldonline.be
Tue Jan 31 10:19:12 PST 2017
Dear all,
Thanks to initial work by Rashad, extensively completed by Markus Metz,
we now have a new addon module which allows to segment images into
so-called superpixels, using the SLIC algorithm as proposed by Achanta
et al [1].
The module uses a spatially constrained kmeans algorithm to group
neighboring pixels into larger ensemble, the "superpixels". These
superpixels can be used as a specific form of segmentation by itself,
or they can be used as seed input to i.segment's region-growing
algorithm.
Thank you very much to the two authors for the great work !
Moritz
[1] http://ivrl.epfl.ch/research/superpixels
