[GRASS-dev] [GRASS GIS] #3364: Zip file and url support for r.import and v.import
GRASS GIS trac at osgeo.org
Sat Jul 1 02:50:42 PDT 2017
 Reporter:  huhabla                          |      Owner:  grass-dev@…
     Type:  enhancement                      |     Status:  new
 Priority:  minor                            |  Milestone:  7.4.0
Component:  Raster                           |    Version:  svn-trunk
 Keywords:  r.import, v.import, zip support  |        CPU:  Unspecified
 Platform:  Unspecified                      |
 This is a feature request to add support for zip files and direct URL
 download to r.import and v.import.
 Zip files may contain a tiff file, shape files or any other zip-
 compressible geodata that can be imported y r.in.gdal and v.in.ogr.
 Checks for zip-bombs should be included. Nested zip files are not
 supported. Counting of files that are included in the archives must be
 performed. By default, only a single file is supported in the archive,
 with the exception of formats that require multiple files like shape-
 files.
 The URL support must check if the files are accessible. HTTP, HTTPS and
 FTP requests should be supported as well as authentication and proxy
 configuration. Mimetype check must be performed before the file is
 downloaded by r.import or v.import via the wget command.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3364>
