[GRASS-dev] [GRASS GIS] #3365: r.in.gdal: crash on large dataset
trac at osgeo.org
Tue Jul 4 12:42:05 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Raster | Version: svn-releasebranch72
Resolution: | Keywords: r.in.gdal
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:2 neteler]:
> Using valgrind:
> GRASS 7.3.svn (latlong):~ > valgrind $CMD
> ==30211== Memcheck, a memory error detector
> ==30211== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et
al.
> ==30211== Using Valgrind-3.12.0 and LibVEX; rerun with -h for copyright
info
> ==30211== Command: r.in.gdal
input=/mnt/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
output=loss_global_forest_cover_loss_2000_2015
> ==30211==
> Importing raster map <loss_global_forest_cover_loss_2000_2015>...
> ==30211== Warning: client switching stacks? SP change: 0xffee9d140 -->
0xffe91ed30
> ==30211== to suppress, use: --max-stackframe=5760016 or greater
> ==30211== Invalid write of size 8
> ==30211== at 0x5273D89: ??? (in
/home/mundialis/software/grass73_svn/dist.x86_64-pc-linux-
gnu/lib/libgrass_raster.7.3.svn.so)
Maybe you need to recompile GRASS with -g in order to replace "???" with
some real information.
I could reproduce the problem, the segfault is caused by stack overflow
because alloca allocates memory in the stack, while malloc and calloc
allocate memory in the heap. I could fix the segfault by replacing
G_alloca()/G_freea() with G_malloc()/G_free(). Please try the attached
patch against lib/raster/.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3365#comment:4>
