[GRASS-dev] [GRASS GIS] #3367: g.gui.animation: animated GIF export generates corrupted GIF files
trac at osgeo.org
Thu Jul 6 06:03:48 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: unspecified
Keywords: g.gui.animation | CPU: Unspecified
Platform: Unspecified |
When exporting an animated GIF, the generated file is corrupted:
# using GRASS 7.2.2svn (nc_climate_spm_2000_2012): >
g.region raster=2002_10_precip -p
g.gui.animation `g.list raster pattern="2*_10_precip" sep=comma`
Default TGIS driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db
WARNING: Temporal database connection defined as:
/home/mneteler/grassdata/nc_climate_spm_2000_2012/climate_1970_2012/tgis/sqlite.db
But database file does not exist.
Creating temporal database:
/home/mneteler/software/grass72/dist.x86_64-pc-linux-
gnu/etc/python/grass/imaging/images2gif.py:344: VisibleDeprecationWarning:
converting an array with ndim > 0 to an index will result in an error in
the future
im2 = im[y0:y1, x0:x1]
(not sure if the warning matters)
-rw-r--r-- 1 mneteler mneteler 1561325 Jul 6 14:55 bla.gif
display: corrupt image `bla.gif' @ error/gif.c/ReadGIFImage/1368.
System:
System Info
GRASS version: 7.2.2svn
GRASS SVN revision: r71233M
Build date: 2017-07-03
Build platform: x86_64-pc-linux-gnu
GDAL: 2.1.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.14.2
Python: 2.7.13
wxPython: 3.0.2.0
Platform: Linux-4.11.3-202.fc25.x86_64-x86_64-with-fedora-25-Twenty_Five
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367>
