[GRASS-dev] [GRASS GIS] #3367: g.gui.animation: animated GIF export generates corrupted GIF files
trac at osgeo.org
Sat Jul 8 18:03:27 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: svn-releasebranch72
Resolution: | Keywords: g.gui.animation
CPU: x86-64 | Platform: Linux
Comment (by annakrat):
My gifs are ok... Could you test this code snippet to see if the problem
is in the images2gif (likely)? Also do you have Pillow or PIL?
import os
from PIL import Image
from grass.imaging import writeGif
color_path = os.path.join(os.environ['GISBASE'], "docs", "html",
"colortables")
pil_images = [Image.open(os.path.join(color_path, c)) for c in
os.listdir(color_path)]
writeGif('/tmp/test.gif', pil_images, duration=0.2, repeat=True)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:6>
