[GRASS-dev] [GRASS GIS] #3368: warnings and errors in compilation log
trac at osgeo.org
Sun Jul 9 04:15:01 PDT 2017
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: All |
looking into the
[https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71243-290/
package.log] regarding warnings and errors during compilations in windows
(zipped log file attached), there are some warnings and error (AFAIR I've
seen them also in my debian 9):
e.g.
make[3]: Leaving directory '/c/msys64/usr/src/grass_trunk/lib/display'
make[3]: Entering directory '/c/msys64/usr/src/grass_trunk/lib/db'
make -C dbmi_base || echo /c/msys64/usr/src/grass_trunk/lib/db/dbmi_base
>> /c/msys64/usr/src/grass_trunk/error.log
make[4]: Entering directory
'/c/msys64/usr/src/grass_trunk/lib/db/dbmi_base'
test -d OBJ.x86_64-w64-mingw32 || mkdir -p OBJ.x86_64-w64-mingw32
gcc -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include
-I/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/alloc.o -c alloc.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/case.o -c case.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/column.o -c
column.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/columnfmt.o -c
columnfmt.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/connect.o -c
connect.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/cursor.o -c
cursor.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/datetime.o -c
datetime.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/dbmscap.o -c
dbmscap.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/default_name.o -c
default_name.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/dirent.o -c
dirent.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/error.o -c error.c
error.c: In function 'db_noproc_error':
error.c:159:6: warning: type of 'procnum' defaults to 'int' [-Wimplicit-
int]
void db_noproc_error(procnum)
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/handle.o -c
handle.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/index.o -c index.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/interval.o -c
interval.c
exec.c: In function 'exec_rectify':
exec.c:61:11: warning: passing argument 1 of 'time' from incompatible
pointer type [-Wincompatible-pointer-types]
time(&start_time);
In file included from exec.c:14:0:
C:/msys64/mingw64/x86_64-w64-mingw32/include/time.h:212:29: note: expected
'time_t * {aka long long int *}' but argument is of type 'long int *'
__CRT_INLINE time_t __cdecl time(time_t *_Time) { return _time64(_Time);
exec.c:80:8: warning: passing argument 1 of 'time' from incompatible
time(&rectify_time);
make -C i.aster.toar || echo
/c/msys64/usr/src/grass_trunk/imagery/i.aster.toar >>
'/c/msys64/usr/src/grass_trunk/imagery/i.aster.toar'
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-DRELDIR=\"imagery/i.aster.toar\" -o OBJ.x86_64-w64-mingw32/gain_aster.o
-c gain_aster.c
-DRELDIR=\"imagery/i.aster.toar\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c: In function 'main':
main.c:314:9: warning: iteration 14u invokes undefined behavior
[-Waggressive-loop-optimizations]
Rast_close(infd[i]);
main.c:312:5: note: containing loop
for (i = 1; i <= MAXFILES; i++) {
main.c:310:13: warning: iteration 14u invokes undefined behavior
Rast_put_row(outfd[i], outrast[i - 1], out_data_type);
main.c:309:9: note: containing loop
main.c:280:13: warning: iteration 14u invokes undefined behavior
Rast_get_row(infd[i], inrast[i - 1], row, in_data_type[i -
1]);
main.c:279:9: note: containing loop
export_areas.c: In function 'export_areas_multi':
export_areas.c:199:13: warning: ignoring return value of
'OGR_L_CreateFeature', declared with attribute warn_unused_result
[-Wunused-result]
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
export_areas.c:248:9: warning: ignoring return value of
[-Wunused-result]
export_areas.c: In function 'export_areas_single':
export_areas.c:101:13: warning: ignoring return value of
[-Wunused-result]
-D_FILE_OFFSET_BITS=64 -I/c/OSGeo4W64/include -I/c/OSGeo4W64/include
-DPACKAGE=\""grassmods"\" -I/c/OSGeo4W64/include
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/export_lines.o -c
export_lines.c
export_lines.c: In function 'export_lines_multi':
export_lines.c:228:13: warning: ignoring return value of
[-Wunused-result]
export_lines.c:275:9: warning: ignoring return value of
[-Wunused-result]
export_lines.c: In function 'export_lines_single':
export_lines.c:135:13: warning: ignoring return value of
[-Wunused-result]
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/list.o -c list.c
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:714:2: warning: ignoring return value of 'OGR_L_StartTransaction',
declared with attribute warn_unused_result [-Wunused-result]
OGR_L_StartTransaction(Ogr_layer);
main.c:760:2: warning: ignoring return value of 'OGR_L_CommitTransaction',
OGR_L_CommitTransaction(Ogr_layer);
make -C v.surf.rst || echo /c/msys64/usr/src/grass_trunk/vector/v.surf.rst
'/c/msys64/usr/src/grass_trunk/vector/v.surf.rst'
-DRELDIR=\"vector/v.surf.rst\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:642:31: warning: passing argument 41 of 'IL_init_params_2d' from
incompatible pointer type [-Wincompatible-pointer-types]
Tmp_fd_yy, Tmp_fd_xy, devi, NULL, cv,
In file included from main.c:40:0:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/interpf.h:115:6:
note: expected 'FILE * {aka struct _iobuf *}' but argument is of type
'char *'
void IL_init_params_2d(struct interp_params *, FILE *, int, int, double,
make -C v.lrs.where || echo
/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.where >>
'/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.where'
-DRELDIR=\"vector/v.lrs/v.lrs.where\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c:88:24: warning: assignment discards 'const' qualifier from pointer
target type [-Wdiscarded-qualifiers]
driver_opt->answer = db_get_default_driver_name();
main.c:95:26: warning: assignment discards 'const' qualifier from pointer
database_opt->answer = db_get_default_database_name();
'/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.label'
-DRELDIR=\"vector/v.lrs/v.lrs.label\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c:126:24: warning: assignment discards 'const' qualifier from pointer
main.c:133:26: warning: assignment discards 'const' qualifier from pointer
'/c/msys64/usr/src/grass_trunk/vector/v.generalize'
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/displacement.o
-c displacement.c
In file included from displacement.c:25:0:
point.h:74:22: warning: inline function 'point_dist_segment_square'
declared but never defined
extern inline double point_dist_segment_square(POINT a, POINT b, POINT c,
point.h:71:22: warning: inline function 'point_angle_between' declared but
never defined
extern inline double point_angle_between(POINT a, POINT b, POINT c);
point.h:68:22: warning: inline function 'point_dist_square' declared but
never defined
extern inline double point_dist_square(POINT a, POINT b);
point.h:65:22: warning: inline function 'point_dist' declared but never
defined
extern inline double point_dist(POINT a, POINT b);
point.h:62:20: warning: inline function 'points_copy_last' declared but
never defined
extern inline void points_copy_last(struct line_pnts *Points, int pos);
point.h:59:20: warning: inline function 'point_scalar' declared but never
defined
extern inline void point_scalar(POINT a, double k, POINT * res);
point.h:51:20: warning: inline function 'point_assign' declared but never
defined
extern inline void point_assign(struct line_pnts *Points, int index,
point.h:46:22: warning: inline function 'point_dist2' declared but never
defined
extern inline double point_dist2(POINT a);
point.h:40:20: warning: inline function 'point_add' declared but never
defined
extern inline void point_add(POINT a, POINT b, POINT * res);
point.h:37:20: warning: inline function 'point_subtract' declared but
never defined
extern inline void point_subtract(POINT a, POINT b, POINT * res);
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/matrix.o -c
matrix.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/misc.o -c
misc.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/network.o -c
network.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/point.o -c
point.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/pq.o -c pq.c
OBJ.x86_64-w64-mingw32/simplification.o -c simplification.c
In file included from simplification.c:24:0:
never defined
never defined
defined
never defined
defined
defined
defined
defined
never defined
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/smoothing.o -c
smoothing.c
In file included from smoothing.c:25:0:
never defined
never defined
defined
never defined
defined
defined
defined
defined
never defined
'/c/msys64/usr/src/grass_trunk/raster3d/r3.retile'
-DRELDIR=\"raster3d/r3.retile\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:110:12: warning: assignment discards 'const' qualifier from pointer
mapset = G_find_raster3d(param.input->answer, "");
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive_impl.h:47:0,
from
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/ami.h:58,
from visibility.h:42,
from viewshed.h:42,
from viewshed.cpp:48:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive.h:
In constructor 'EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)':
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive.h:69:47:
warning: delegating constructors only available with -std=c++11 or
-std=gnu++11
EMPQueueAdaptive(long N) : EMPQueueAdaptive() {};
viewshed.cpp: In function 'AEvent* allocate_eventlist(GridHeader*)':
viewshed.cpp:154:59: warning: left shift count >= width of type [-Wshift-
count-overflow]
long long maxsizet = ((long long)1 << (sizeof(size_t) * 8)) - 1;
c++ -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include
-D_FILE_OFFSET_BITS=64 -DUSER=\"\" -Wno-sign-compare
-DRELDIR=\"raster/r.viewshed\" -o OBJ.x86_64-w64-mingw32/visibility.o -c
visibility.cpp
from
from visibility.cpp:46:
-std=gnu++11
-std=gnu++11
main.cpp: In function 'void parse_args(int, char**, int*, int*,
ViewOptions*, long long int*, Cell_head*)':
main.cpp:502:24: warning: deprecated conversion from string constant to
'char*' [-Wwrite-strings]
obsElevOpt->answer = "1.75";
main.cpp:514:24: warning: deprecated conversion from string constant to
tgtElevOpt->answer = "0.0";
main.cpp:557:26: warning: deprecated conversion from string constant to
refrCoeffOpt->answer = "0.14286";
main.cpp:571:26: warning: deprecated conversion from string constant to
memAmountOpt->answer = "500";
Status: Preprocessing c:\users\landa\appdata\local\temp\tmpfva_ht.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
c:/users/landa/appdata/local/temp/tmpfva_ht.h
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\include\grass\gis.h:24,
c:/users/landa/appdata/local/temp/tmpfva_ht.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: ^
Status: Parsing c:\users\landa\appdata\local\temp\tmpfva_ht.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:144: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:150: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:156: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:161: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:170: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:176: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:188: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:381: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:382: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:383: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:393: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:394: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:395: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:529: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:538: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:543: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:545: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:567: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:577: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:581: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:585: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:592: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:594: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:598: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:602: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:729: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:730: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:731: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:757: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:758: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:787: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:789: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:799: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:804: Syntax
error at 'argp'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:811: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:813: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:821: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:27:
Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:36:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:37:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:39:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:42:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:45:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:57:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:58:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:59:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:61:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:64:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:65:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:68:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:69:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:72:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:73:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:76:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:77:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:79:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:81:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:83:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:85:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:88:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:89:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:107:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:108:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:110:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:116:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:124:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:126:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:128:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:130:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:145:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:146:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:148:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:150:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:153:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:154:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:157:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:158:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:161:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:162:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:165:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:167:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:169:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:170:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:63:
Syntax error at '{'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:64:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:138:
Status: Preprocessing c:\users\landa\appdata\local\temp\tmplwqipi.h
c:/users/landa/appdata/local/temp/tmplwqipi.h
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\include\grass\segment.h:4,
c:/users/landa/appdata/local/temp/tmplwqipi.h:1:
compiler
Status: Parsing c:\users\landa\appdata\local\temp\tmplwqipi.h
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at ';'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368>
