[GRASS-dev] [GRASS GIS] #3367: g.gui.animation: animated GIF export generates corrupted GIF files
GRASS GIS trac at osgeo.org
Sun Jul 9 14:28:36 PDT 2017
  Reporter:  neteler  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  reopened
  Priority:  normal   |  Milestone:  7.2.2
 Component:  wxGUI    |    Version:  svn-releasebranch72
Resolution:           |   Keywords:  g.gui.animation
       CPU:  x86-64   |   Platform:  Linux
Comment (by annakrat):
 Could you test any of the available versions of images2gif.py files from
 different repositories? I found couple for example:
 https://bitbucket.org/bench/images2gif.py/raw/a618bd8fc352f278a3b0c777cb6427ec39236f0a/images2gif.py
 https://github.com/isaacgerg/images2gif/blob/master/images2gif.py
 https://gist.github.com/jonschoning/7216290
 https://github.com/rec/echomesh/blob/master/code/python/external/images2gif.py
 If you replace the import with
 {{{ from images2gif import writeGif}}}
 then the test code snippet should work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:10>
