[GRASS-dev] GRASS on Mac
Luca Delucchi
lucadeluge at gmail.com
Mon Jul 10 04:35:41 PDT 2017
On 10 July 2017 at 12:49, Rainer Krug <rainer_krug at icloud.com> wrote:
> Hi Luca,
Hi Rainer,
thanks for the answer...
>> On 10 Jul 2017, at 12:08, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> Hi devs,
>> I'm trying to install GRASS on a MAC El Capitan version.
>> I read in a previous mail that Anna suggests to use Homebrew, I
>> followed that suggestion and at the end I got this error [0]. Do you
>> have any idea?
>> Is Homebrew the better/simpler way to install GRASS on MAC?
> It is the only way of installing GRASS on ElCapitan or newer without disabling SIP (as far as I am aware).
ok, but if SIP i disabled what can I test?
> This just tells us that there was an error and where it was, but not what it was.
> Please use the -d option when installing, and paste the whole command to let us know what options you used for installing grass7.
> If --debug (or -d) is passed and brewing fails, open an interactive debugging
> session with access to IRB or a shell inside the temporary build directory.Then when the error occurs, you can drop
> Also, run
> brew doctor
> to check you homwebrew installation.
ok, thanks for suggestions
ciao
Luca
www.lucadelu.org
